Line render options
Command
Path
View bar
Line Render Options
View > Rendering
Use the line render options to control the appearance of lines in Hidden Line and Dashed Hidden Line modes. These settings apply only to the current drawing; they remain in effect in the current drawing until the settings are changed. The current line render settings are saved when you create a template (see Concept: Templates).
For sheet layer viewports and section viewports that use Hidden Line render mode, additional depth cueing options are available. Depth cueing in Hidden Line mode adjusts the line thickness and fading to indicate distance from the camera. This provides a more realistic rendering for perspective and orthogonal views; see Applying depth cueing to a viewport. To set depth cueing for a selected viewport, click Background/Foreground Render Settings on the Object Info palette, depending whether hidden line is used for the background or foreground render mode; when the Hidden Line Render Settings dialog box opens, a Depth Cueing tab is available.
To set line rendering options:
Select the command. The Line Render Options dialog box opens, set the parameters.
Alternatively, if a different render mode is active, select the command under Options For Other Render Modes in the Current Render Mode menu on the View bar.
Parameter
Description
Dash Style
Select the dash style for hidden lines when the Dashed Hidden Line mode is selected
Dash Shade
Adjust the slider to select how hidden lines are shaded when the Dashed Hidden Line mode is selected
Preview
Displays a preview of the selected parameters
Smoothing Angle
Sets the angle to reduce facet lines when the Hidden Line mode or Dashed Hidden Line mode is selected; if the value is greater than zero, facet lines will be removed between any two faces of an object that are within that angle of each other
Generate intersecting lines
Generates lines where surfaces in the drawing intersect each other when the Hidden Line mode or Dashed Hidden Line mode is selected; for large files with a lot of curved surfaces, this option can make rendering slower
Display surface hatches
Displays surface hatches in a hidden line rendered view
Display text and markers
Displays text and markers in the rendered view.
Hiding text and markers can significantly decrease rendering times.
Sketch hidden line results
(Design Suite product required)
Specifies whether to apply sketch effects to lines when the Hidden Line mode or Dashed Hidden Line mode is selected; see Sketch rendering
Document/Viewport Default Sketch Style
Sets the default sketch style for lines when the Hidden Line mode or Dashed Hidden Line mode is selected; see Sketch rendering. Click Edit to open the Sketch Style Editor dialog box for additional sketch style modification. For a viewport, click Preview to preview the change in the viewport.
Depth Cueing
Available when the dialog box is opened from the Object Info palette of a sheet layer viewport or section viewport. See Applying depth cueing to a viewport.
Rendering modes
